Extend LANs
Jul 26th, 2010
Hi All,
We have 2 sites(A and B) in london and are merging into one site A. Switches from the site B will be reconfigure for site A subnet. We are also extending site A from 3rd floor to 5th floor.
we are using 10.9.1.x in site A. Plan is to use fibre channel for 3rd and 5th floor switch connections. Its my first time, does any one please explian how fibre channel will work, is it some thing 3rd party will come and carry out the work for fibre communication? at the end I will plug the cables in Cisco GE SFP, LC connector SX transceiver GLC-SX-MM in these connectors.???
We have total 5 sites using MPLS cloud, for the new 5th floor in site A if we want to use another subnet 10.91.1.x for IP phones can we use it? will it be another VLAN? with one gateway?
Please can any explain about extended LANS's /VLAN, help would be highly appreciated.
Jag
Leo Laohoo Mon, 07/26/2010 - 19:32
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
EtherChannel is a technology where you "bind" a minimum of two (and a maximum of eight) links of the same speed and duplex into one link.  This technology is beneficial if you are talking about load balancing and redundancy.
http://www.cisco.com/en/US/tech/tk389/tk213/tsd_technology_support_protocol_home.html
205000jag Tue, 07/27/2010 - 01:56
Thanks for the info leo,
So for fibre connection, is it some thing a 3rd part i.e. phone communication involved for the connection from 3rd floor to 5th floor, or is it I/we have to take the wire/fibre connection upstairs?
Could also please advice my other question/ confusions
Jag
Leo Laohoo Tue, 07/27/2010 - 15:28
  • Hall of Fame,
    2017 LAN, Wireless
You'll need to engage a 3rd party cable contractor to run cables (fibre optic or copper) from one floor to another.
