Calling Party Transformation and MGCP
Jul 26th, 2010
I am running System version: 7.0.2.23900-4. Calling Party Transformations are not taking effect on MGCP GW. The exact same config works if I change the GW type to H323.
I am attempting to set the caller-id to 201-201-2000 but it is not taking.
The PSTN is not restricting caller id.
Calling Party Transformation Patterns
201201XXXX    hq-calling-xform-out
2XXX    hq-calling-xform-out
Calling Party Transformation Mask 2012012000
Route Pattern Configuration
9.[2-9]XXXXXX
Use Calling Party's External Phone Number Mask is unchecked
System-RL specifies local route group
Route group config:
Use Calling Party's External Phone Number Mask is set to off
GW configuration
Use Device Pool Calling Party Transformation CSS is unchecked
    hq-gw-calling-xform-out
Partition: hq-calling-xform-out
Calling phone 2001 external phone mask 20120122XXX
the caller id being sent to the PSTN is 2001
thanks
fossilev700 Mon, 07/26/2010 - 08:30
Issue resolved by doing a no mgcp / mgcp on the gateway. I had rebooted the gateway but apparently mgcp must be reset when a change is made to the calling party transformations...its always something simple
