IOS upgrade using LMS3.2
Answered Question
Jul 26th, 2010
Hi All,
I want to upgrade a Cisco 6509-E to a newer IOS using LMS3.2 (never done it before using LMS).  The switch has a flash disk size of 128Megs and the current IOS is about 80Megs, so there is only about 46 Megs available on the flash card.  Questions?
Is the behaviour of LMS to delete the current IOS version on the flash card if not enough space available for the new one? Or do I need to buy a bigger card? And any tips are welcome for the ones that have done it before this way....
Thank you in advance....
Cheers!
Correct Answer by Sven Hruza about 6 years 10 months ago
LMS should delete the present IOS version.
But in that case you don't have the now running IOS version for emergency fallback or something like that.
Sven
Overall Rating: 5 (1 ratings)
Correct Answer
Sven Hruza Mon, 07/26/2010 - 09:55
  • Bronze, 100 points or more
Sven
