ASA/PIX Order of Operations
manuadoor
Can Someone put some light on the Order of Operations (what all happnes when paket comes to interface) in ASA/PIX. Is there any difference when direction changes.
5 Replies 5
August Ritchie
Perhaps this is what you were looking for?
https://learningnetwork.cisco.com/message/62746
Actually the list is quite long and detailed... depending on the features that you have...
But just to give you an example...
When a packet comes to an interface normally this happens:
ACL checking
Routing
NAT
Encryption
Obviously, if you have other features like AAA, application inspection, etc... then they also come into play.
When the packet arrives to its destination, the packet is first decrypted, and then all the rule applies.
The above is very general and is just to give you an idea.
Federico.
The Packet-Tracer option will provide all this informacion
https://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807c35e7.shtml#s3
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
MAC Access list
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 3
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   172.22.1.0      255.255.255.0   outside
Phase: 5
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group inside_acl in interface inside
access-list inside_acl extended permit tcp 192.168.1.0 255.255.255.0 any eq www
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Phase: 8
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (inside) 1 192.168.1.0 255.255.255.0
  match ip inside 192.168.1.0 255.255.255.0 outside any
    dynamic translation to pool 1 (172.22.1.254)
    translate_hits = 6, untranslate_hits = 0
Dynamic translate 192.168.1.50/1025 to 172.22.1.254/1028
using netmask 255.255.255.255
Phase: 9
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
Phase: 10
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Phase: 11
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 13
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Phase: 14
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 94, packet dispatched to next module
Phase: 15
Type: ROUTE-LOOKUP
Subtype: output and adjacency
Result: ALLOW
Config:
found next-hop 172.22.1.1 using egress ifc outside
adjacency Active
next-hop mac address 0030.a377.f854 hits 11
!--- The MAC address is at Layer 2 of the OSI model.
!--- This tells the administrator the next host
!--- that should receive the data packet.
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
I'm pretty sure that "FLOW" comes before "ACL"
I dont think the above packet-tracer commands ACL refers to the typical ACL. It comes later on the packet-tracer output.
MAC Access list
- Jouni
