07-26-2010 07:02 AM - edited 03-06-2019 12:11 PM
Anyone know why this happens? I'm trying to enter a static arp entry and assign it to a specific vlan, for example:
arp 192.168.200.1 aaaa.bbbb.cccc arpa vlan 15
% Invalid input detected at '^' marker
When this is entered it errors out and marks the word vlan like it is invalid, though it is a valid option when inching forward using the ? help character. I tried multiple iterations and the only other response I get is if I enter vlan 1. To that the router responds with:
Bad ARP command - Interface may only be specified when bridging IP
Is one to assume that the vlan need not be specified? I opted to enter the vlan only for uniformity, but then when it behaved strangely I became curious. I wonder in what scenario adding the vlan to an arp entry would be valid and acceptable.
Thanks, Mike
Solved! Go to Solution.
07-26-2010 07:32 AM
What you experienced is the normal behavior. The L3 device does not allow
you to specify the interface when you are operating in routed mode. Based on
the address you have configured, it will automatically allocate the static
ARP entry to appropriate interface. If you have entered an IP that does not
belong to any subnet, then all interfaces will consider that ARP entry. Only
if you configure two interfaces in bridge mode (like in the case of PPPoE
scenarios), then you can specify the interface ID.
Hope this helps.
NT
07-26-2010 07:32 AM
Hope this helps.
NT
12-06-2013 09:26 AM
Dear all
I get the same problem
can anyone tell me how to set static arp for an IP in a vlan on a L3 Cisco switch
Tks so much
06-24-2018 05:29 AM
it can be quite late... but it's just
