Agent UCCX display
Jul 26th, 2010
Can be displayed in the agent,  when it receives the call, the script menu options were selected? What can i do to do this?
Michael Odom Mon, 07/26/2010 - 09:16
You can, but it does require a little bit of scripting.  Basically you will use the Set Enterprise Call Info step and assign the information to one or more Call.PeripherialVariableX.  You will also need to use the Desktop Administrator to assign the variable to the Agent Desktop software.
IPCC Editor Step Reference (start about pg 96)
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/user/guide/uccx701edstepref.pdf
Desktop Administrator User Guide (start about page 126)
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_7_0/user/guide/cda66ug-cme.pdf
Gabriel Saavedra Mon, 07/26/2010 - 18:35
When you use the menu step to make the callers to choose an option, then you can use the "set" step to store the option in a variable and then push that variable in the CAD with the information that Michael had posted.
Start
Accept
Menu
     First Option
          set = "MenuOption1"
     Second Option
          set = "MenuOption2"
Set Enterprise Call info
Select Resource
End
Gabriel
