ITS Telecom Pantel IP (Door Phone ) + Callmanager
Jul 26th, 2010
Hi everybody,
does any have an idea about the compatibility between Pantel IP and CUCM 7.0 ?
If there is any documentation, please send me the link
Hicham
Benjamin Krueger Wed, 02/01/2012 - 06:14
Hi Hicham,
I have the same problem.
Did you make the registration with a Pantel IP door line and the Communications Manager?
kind regards
Benjamin
Benjamin Krueger Thu, 02/02/2012 - 04:33
Hi Alex,
Thank you very much for your help ;-)!
Its working now.
Kind regards
Benjamin
Mit freundlichen Gruessen - Best regards
Benjamin Krueger
Technology Specialist
Unified Communications & Collaboration
Computacenter AG & Co oHG
Services & Solutions
Voltastraße 1, 60486 Frankfurt, Germany
Tel.: +49 69 97779 255
Mobile: +49 172 8153319
Fax: +49 69 97779 252
Short-Dial: 522255
E-Mail: [email protected]
WWW: www.computacenter.de
Von: acampbell
Gesendet: Mittwoch, 1. Februar 2012 17:42
An: Krueger, Benjamin
Betreff: - Re: ITS Telecom Pantel IP (Door Phone ) + Callmanager
Home
created by acampbell in IP Telephony - View the full discussion
acampbell Thu, 02/02/2012 - 07:20
  • Green, 3000 points or more
So did using a SIP trunk resolve the issue
Alex
Please rate useful posts and close your case as correct answer provided.
Benjamin Krueger Thu, 02/02/2012 - 07:30
Yes that’s right, I added a SIP trunk and let the doore line make calls to the reception.
Once again thank you ;-)!
Kind regards
Benjamin
Benjamin Krueger
Short-Dial: 522255
Von: acampbell
Gesendet: Donnerstag, 2. Februar 2012 16:21
Home
Benjamin Krueger Thu, 02/02/2012 - 23:16
Hi Alex,
Sorry to interrupt you again. But I have other problem with the door line.
DTMF tones are not “hear” at the door line. I configured the trunk with the option DTMF signaling method RFC 2833, on the door line I use the same DTMF option (RFC 2833), but when the reception press a number to open the door, the door line doesn’t open. We use 7962 SCCP phones.
Have you an idea what I can do, that DTMF is transferred via the trunk?
Kind regards
Benjamin
Von: acampbell
Home
