CER on VM
Answered Question
Jul 26th, 2010
Hi can can anyone tell me if Cisco Emergency Responder is supported in a VM enviroment?
Correct Answer by htluo about 7 years 1 day ago
It depends on the definition of "support" and the CER version.
On UC (Unified Communication) 8.x, VMWare is supported.  However, depending on individual products, it may or may not be stated (clearly) in release notes or compatiblility guides.
On pre-8.x version, you may install CER on VMWare.  It will work with some tuning.  But it's not supported by Cisco TAC.
See: http://htluo.blogspot.com/2009/07/cisco-software-on-vmware.html
Michael
Correct Answer by Jaime Valencia about 7 years 1 day ago
No, 8.0 is the latest one and this are the supported platforms.
Table 6     Supported MCS Platforms
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cer/8_0/English/release/notes/cer_801.html#wp41370
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (2 ratings)
Correct Answer
htluo Mon, 07/26/2010 - 18:58
  • Red, 2250 points or more
Michael
