IPSEC packet has invalid spi
Jul 26th, 2010
I have a very simple LAN-2-LAN between two cisco routers running IOS version 12.4(15)T8 as follows:
RouterA:
crypto isakmp key test123 address 4.2.97.15 no-xauth
crypto isakmp policy 1
encr aes 256
hash sha
authentication pre-share
group 5
lifetime 86400
no crypto ipsec nat-transparency udp-encapsulation
crypto ipsec transform-set tset esp-aes 256 esp-sha-hmac
crypto map vpn 10 ipsec-isakmp
set peer 4.2.97.15
set security-association lifetime seconds 3600
set transform-set tset
set pfs group5
match address vpn
interface FastEthernet0/0
ip address 207.15.205.15 255.255.255.0
speed 100
full-duplex
crypto map vpn
ip access-list extended vpn
permit ip 129.174.15.0 0.0.0.255 129.174.16.0 0.0.0.255
RouterB:
crypto isakmp key test123 address 207.15.205.15 no-xauth
encr aes 256
hash sha
group 5
lifetime 86400
set peer 207.15.205.15
set pfs group5
match address vpn
ip address 4.2.97.15 255.255.255.0
speed 100
full-duplex
crypto map vpn
permit ip 129.174.16.0 0.0.0.255 129.174.15.0 0.0.0.255
Every now and then I am seeing this message in the log file:
Jul 27 00:25:20.603: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd
IPSEC packet has invalid spi for destaddr=207.15.205.15, prot=50,
spi=0x681E0955(1746798933), srcaddr=4.2.97.15.
Why am I seeing this message?  The VPN peer between two router is very stable without any errors.
I've asked several ccie consultant folks and none of them is able to provide me with a satifactory answer regarding this message.
Anyone know why?  Thanks in advance.
Overall Rating: 5 (5 ratings)
manish arora Mon, 07/26/2010 - 18:33
This generaly happens when the peer recieves an IPSEC packet that specifies an SPI that does not exist in the Security association database, which means that keys that were generated by IKE to encrypt the ipsec packets is not known or has expired at the peer that recieved the packet. This could be because of slight aging difference between the SA's on the ipsec peers or because the local SA was cleared or an invalid packet was sent by the peer.
If this activity is happening a lot then it could be considered as an hostile event.
thanks
Manish
Jitendriya Athavale Mon, 07/26/2010 - 22:22
if everything is working fine, then seeing such message could only mean one thing
when your SA lifetime is about to expire ipsec will do a rekey and generate new SA's, now during this transistion peroid which is briefly around a second 2 SA's are active so that there is no loss of traffic due to rekey
however what happens is sometimes during this rekey there is a possibility that one peer has generated the new SA but the other one is still in the process of doing it, thats when you will see these messages
we can confirm this by a simple experiment - inc/dec of lifetime should affect the frequecy of these messages
please mark this thread as answered for benifit of others if you are satisfied with our explanation
bule.msowoya Mon, 02/03/2014 - 23:49
I know its been a while since this was asked but to help anyone who may still want to know here is the reason from Cisco:
It simply means IPsec Security Associations are out of sync       between the peer devices. As a result, an encrypting device will encrypt       traffic with SAs that its peer does not know about. These packets are dropped       on the peer with the above message logged to the syslog
Read more here: http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a0080bf6100.shtml
One of the most common IPsec issues is that SAs can become out of sync       between the peer devices. As a result, an encrypting device will encrypt       traffic with SAs that its peer does not know about. These packets are dropped       on the peer with this message logged to the syslog:
Sep  2 13:27:57.707: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet
   has invalid spi for destaddr=20.1.1.2, prot=50, spi=0xB761863E(3076621886),
   srcaddr=10.1.1.1
babsoncisco27 Fri, 06/10/2016 - 13:15
just issue a "clear crypto isakmp" and "clear crypto sa" on the spoke(s). That will clear up the security association and resync with the new one with the hub. Moving forward, add the "crypto isakmp invalid-spi-recovery" command in your config.
plavine Tue, 07/12/2016 - 20:26
I found that this may occur when the ACLs defining interesting traffic are one-sided.
Make sure that the ACL mirror each other especially when building IPSEC tunnels between an ASA and an IOS based device.
