Unable to Ping Hosts Through IPSec Tunnel
cfinotti22
I have a home lab setup with a PIX 515 running 8.03 code.  I have made several changes over the past week and now when I terminate a VPN connection to the outside interface I am unable to hit any internal resources.  My VPN connection is coming from a 10.22.254.0/24 trying to hit internal nodes at 10.22.1.0/24, see below.  When I terminate a VPN connection against the inside interface it works, so I take it I'm dealing with a NAT issue?   I don't have a clue why Phase 9 is failing:-\  Any help would be great!
access-list nonat extended permit ip 10.22.254.0 255.255.255.0 10.22.1.0 255.255.255.0
nat (inside) 0 access-list nonat
global (outside) 1 interface
access-list split extended permit ip 10.22.1.0 255.255.255.0 10.22.254.0 255.255.255.0
packet-tracer input inside tcp 10.22.1.15 1025 10.22.254.15 3389 detailed
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   0.0.0.0         0.0.0.0         outside
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Forward Flow based lookup yields rule:
in  id=0x2bb3450, priority=0, domain=permit-ip-option, deny=true
        hits=17005, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0
Phase: 4
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
in  id=0x304ae48, priority=12, domain=ipsec-tunnel-flow, deny=true
        hits=17005, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Phase: 5
Type: NAT-EXEMPT
Subtype:
Result: ALLOW
Config:
nat-control
  match ip inside 10.22.1.0 255.255.255.0 outside 10.22.254.0 255.255.255.0
    NAT exempt
    translate_hits = 6, untranslate_hits = 5
in  id=0x2be2a00, priority=6, domain=nat-exempt, deny=false
        hits=5, user_data=0x2be2960, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
        src ip=10.22.1.0, mask=255.255.255.0, port=0
        dst ip=10.22.254.0, mask=255.255.255.0, port=0
Phase: 6
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
static (inside,DMZ) 10.22.1.0 10.22.1.0 netmask 255.255.255.0
nat-control
  match ip inside 10.22.1.0 255.255.255.0 DMZ any
    static translation to 10.22.1.0
    translate_hits = 10, untranslate_hits = 0
in  id=0x2d52800, priority=5, domain=host, deny=false
        hits=21654, user_data=0x2d51dc8, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (inside) 1 0.0.0.0 0.0.0.0
nat-control
  match ip inside any outside any
    dynamic translation to pool 1 (192.168.20.20 [Interface PAT])
    translate_hits = 2909, untranslate_hits = 9
in  id=0x2d4a7d0, priority=1, domain=nat, deny=false
        hits=16973, user_data=0x2d4a730, cs_id=0x0, flags=0x0, protocol=0
Phase: 8
Type: VPN
Subtype: encrypt
Result: ALLOW
Config:
out id=0x3328000, priority=70, domain=encrypt, deny=false
        hits=0, user_data=0x1efa0cc, cs_id=0x0, reverse, flags=0x0, protocol=0
        dst ip=10.0.0.0, mask=255.0.0.0, port=0
Phase: 9
Type: ACCESS-LIST
Subtype: ipsec-user
Result: DROP
Config:
out id=0x3329a48, priority=69, domain=ipsec-user, deny=true
        hits=37, user_data=0x0, cs_id=0x0, flags=0x0, protocol=0
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
No, the nonat ACL only requires defining traffic from the internal network to the
VPN pool.  You should remove the other entries.
Remove:
access-list nonat line 8 extended permit ip 10.22.254.0 255.255.255.0 object-group DM_INLINE_NETWORK_18
access-list nonat line 8 extended permit ip 10.22.254.0 255.255.255.0 10.22.1.0 255.255.255.0
29 Replies 29
rahgovin
Level 4
Level 4
Could you check up with your vpn filter for the tunnel? It must be within your group-policy with the command vpn-filter value. If it is present, remove the same with the command vpn-filter none.
For more info on vpn-filter:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00808c9a87.shtml
I did not configuered a VPN filter for this Group Policy, see below.
group-policy vpnclient internal
group-policy vpnclient attributes
dns-server value 4.2.2.2
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split
I am receiving the following error when I ping into the tunnel, is this not a NAT issue?
3  Jul 27 2010    05:36:54    106014    Deny inbound icmp src outside:10.22.254.51 dst inside:10.22.1.15 (type 8, code 0)
It's very strange...  If I do a continuous ping to the IP and it will eventually start responding after 10 minutes or so?
c:\>ping 10.22.1.15 /t
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 10.22.1.15: bytes=32 time=25ms TTL=127
Reply from 10.22.1.15: bytes=32 time=26ms TTL=127
Reply from 10.22.1.15: bytes=32 time=61ms TTL=127
Reply from 10.22.1.15: bytes=32 time=52ms TTL=127
Reply from 10.22.1.15: bytes=32 time=98ms TTL=127
Deny when telnetting to a port:
c:\>telnet 10.22.1.15 3389
Connecting To 10.22.1.15...
2 Jul 27 2010 05:59:15    106001    10.22.254.51    3083    10.22.1.15    3389    Inbound TCP connection denied from 10.22.254.51/3083 to 10.22.1.15/3389 flags SYN  on interface outside
can you attach your entire config if its not a prob, u can mask the pub ip's
Thanks for the quick responses!!
Sorry it took so long I had to scrub the config and make a few changes.
Can you post the "show run all group-policy" output?
can you run the following command and post the output of:
show run all | grep sysopt
Thanks.
Nothing displays.
# show run all | grep sysopt
The complete config is listed above.
Try configuring ICMP inspection...
policy-map global_policy
class inspection_default
  inspect icmp
It is not an inspection rule.  I can't hit any resources on the inside once I terminate my IPSec connection.
2    Jul 27 2010    12:13:52    106001    10.22.254.51    2936    10.22.1.15    3389    Inbound TCP connection denied from 10.22.254.51/2936 to 10.22.1.15/3389 flags SYN  on interface outside
I added your policy commands and they did not fix the issue.
It looks like at phase 9 your traffic is blocked by an ACL.  Your VPN traffic should not be subjected to ACLs.  This command may help you here:
sysopt connection permit-vpn
Here's more on the command:
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/s8.html#wp1412217
Good luck.
I enabled the command and I'm still being denied.
#sh run all sysopt
no sysopt connection timewait
sysopt connection tcpmss 1380
sysopt connection tcpmss minimum 0
no sysopt nodnsalias inbound
no sysopt nodnsalias outbound
no sysopt radius ignore-secret
no sysopt connection reclassify-vpn
Can you disable nat-control?
#no nat-control
Same issue..
