C1700 setup, no internet access...
Answered Question
Jul 26th, 2010
Hello!
   New to 1710 setup, I have been fighting this for awhile and am getting back to it. One Vlan, everything passes fine with the connections but no internet access from PCs on the Vlan1 side to FA0, to the DSL router <non-Cisco, providers box>. Below is my config, would love some help or a better config to use that will get the access I need. I'm sure it's something simple I am missing.Oddly enough I can connect to the providers DSL modem fine in a browser, just not past that. <Some areas censored...>
Thanks!
Carl
!This is the running config of the router: 192.168.1.64
!version 12.4
hostname C1700
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1xxF/Z$.gai39xxxxxxxxxxxxxx/
enable password cisco
no aaa new-model
clock timezone Chicago -6
clock summer-time Chicago date Apr 6 2003 2:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.1 192.168.2.9
ip dhcp excluded-address 192.168.2.20 192.168.2.254
ip dhcp pool DHCP1
   import all
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
ip cef
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
crypto pki trustpoint TP-self-signed-cccccccc
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-ccccccccccc
revocation-check none
rsakeypair TP-self-signed-ccccccccc
crypto pki certificate chain TP-self-signed-ccccccccccc
certificate self-signed 01
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
  quit
username xxxxx privilege 15 password 0 xxxxx
interface FastEthernet0
description $ETH-WAN$
ip address dhcp client-id FastEthernet0
ip access-group sdm_fastethernet0_in in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
shutdown
interface Vlan1
ip address 192.168.2.1 255.255.255.0
ip access-group sdm_vlan1_in in
ip nat inside
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet0 permanent
ip http server
ip http authentication local
ip http secure-server
ip nat pool Pool1 192.168.2.3 192.168.2.9 netmask 255.255.255.0
ip nat inside source list 1 interface FastEthernet0 overload
ip access-list extended sdm_fastethernet0_in
remark SDM_ACL Category=1
remark Auto generated by SDM for NTP (123) 129.6.15.28
permit udp host 129.6.15.28 eq ntp any eq ntp
remark Auto generated by SDM for NTP (123) 129.6.15.29
permit udp host 129.6.15.29 eq ntp any eq ntp
remark Permit_All
permit ip any any
ip access-list extended sdm_vlan1_in
permit udp host 129.6.15.28 eq ntp host 192.168.2.1 eq ntp
permit udp host 129.6.15.29 eq ntp host 192.168.2.1 eq ntp
remark Permit_All
permit ip any any
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.2.0 0.0.0.255
control-plane
line con 0
line 1
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
privilege level 15
password xxxxx
login local
transport input telnet ssh
ntp clock-period 17180018
ntp server 129.6.15.29 source FastEthernet0 prefer
ntp server 129.6.15.28 source FastEthernet0 prefer
end
Correct Answer by Nagaraja Thanthry about 6 years 11 months ago
Can you ping internet from the router itself? Can you try to ping 4.2.2.2
from the router?
Also, check the output of "show ip route" on the router to see if the
default gateway is set properly. You might want to remove "ip route 0.0.0.0
0.0.0.0 FastEthernet0 permanent" and let the dhcp server (ISP dhcp server)
provide the default gateway information to the router.
Hope this helps.
NT
Overall Rating: 4.5 (2 ratings)
Nagaraja Thanthry Mon, 07/26/2010 - 21:34
  • Cisco Employee,
Your configuration looks good. One thing I see missing in your DHCP
configuration is the DNS server information. Have you tried to access the
internet using IP address instead of URL? If not, can you please try to
access google.com using 74.125.19.147 IP address? If that works, could you
please try the following:
ip dhcp pool DHCP1
import all
dns-server
exit
Hope this helps.
NT
cmedley67 Thu, 07/29/2010 - 16:47
I will try adding the DNS, thoughtI had. :-)
For a basic router setup where you want it to be wide open, do I have to have an access list? Seems like everytime I try to set a list, I get locked out.
Thanks again!
Carl
Nagaraja Thanthry Thu, 07/29/2010 - 22:39
  • Cisco Employee,
You are correct, you do not need to worry about the Access-list if you are opening up the router for all access.
NT
cmedley67 Fri, 08/06/2010 - 06:17
   I added the DNS entry and when I ping Google, I do get the initial DNS resolution which shows the conversion to an IP address. However, the pings themselves still give "Request timed out" and I still have no internet access.
   I did end up resetting my config to strip it down a little more in hopes of simplifying, but I'm still at the same problem with the exception that now I get the IP resolution.
   One add'l note that I wanted to mention, I AM able to ping and access my DSL gateway, open it's web config page, etc. I'm just not getting any internet access beyond that. I have even thrown the 1700 into the DMZ so that the DSL box passes the external IP to the 1700 but no luck, which leads me back to thinking it's a 1700 config issue. Am I wrong? I'm sure I'm just overlooking something.
Appreciate the help!
Carl
Correct Answer
Nagaraja Thanthry Fri, 08/06/2010 - 06:47
  • Cisco Employee,
from the router?
Hope this helps.
NT
cmedley67 Sat, 08/07/2010 - 12:23
Hello!
   Removing the default 0.0.0.0. route made the difference! I was thinking you had to have either a static route or a dynamic route protocol running in order for routing to occur.
   One add'l question, I have completed the security audit and let it fix everything , with the version of IOS I have <12.4 (23)>, is it safe enough for exposure to the internet? I'm not blessed enough to have access to newer IOS downloads, SDM updates etc, don't want to risk being unsecured enough but want to be able to use it behind the DSL modem in the DMZ so I can use VPN, etc. Thoughts?
Appreciate all the help!
Carl
Nagaraja Thanthry Sat, 08/07/2010 - 14:54
  • Cisco Employee,
12.4(23) does not seem to be affected by any Security vulnerabilities. You could use it on the router. If you find a document that suggests that the IOS is vulnerable, you could request for a fixed IOS version through TAC (keep the document that states the image is vulnerable handy).
Hope this helps.
NT
jimmysands73_2 Sun, 08/08/2010 - 16:35
  • Silver, 250 points or more
I am curious, when the def gateway information is provided to the router, will it show up in sh ip route?
Just curious.....
Nagaraja Thanthry Sun, 08/08/2010 - 16:43
  • Cisco Employee,
It will show up as gateway of last resort. Also, when you configure static
route, it will show up at the very end.
NT
jimmysands73_2 Sun, 08/08/2010 - 18:04
I am curious......
Why didnt that statement work?   If we forward everything out the interface to the ISP to take over, what additional information is provided by the DHCP server to make this work (or do we have enough information to answer that)?
Thank you
Nagaraja Thanthry Sun, 08/08/2010 - 18:24
  • Cisco Employee,
When you have the static route "ip route 0.0.0.0 0.0.0.0 FastEthernet0"
command, the router ARPs for every internet destination on the FastEthernet0
interface. At this point, the ISP router need to respond to those ARP
requests, then only the communication will be possible. If the ISP router
does not reply to ARP requests (which is the general case), the router
(1700) has to drop the packets.
On the other hand, if you let the DHCP assign the IP address and set the
default route (DHCP generally sends the default router information along
with IP address), the router will ARP for the default gateway (which
off-course the ISP router will respond to) and then forward all traffic to
the ISP router.
So, to summarize, in the first case, the 1700 will not know whom to forward
the traffic to and in the second case, through dhcp, the 1700 knows who the
default gateway is and will forward all traffic to that default gateway.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00800e...
.shtml
Hope this helps.
NT
jimmysands73_2 Sun, 08/08/2010 - 18:36
Hope this helps????
You rock....thank you for your informative explanation, it helped me alot.
Thank you,
Jimmy
btw, if it matters, I ranked you 5, but moved my mouse right before I clicked, it rated 4, but you should of recv'd a 5!
