Zone based firewall DMZ NAT problem
I have two WANs. WAN1 is the primary interface for my LAN. The WAN2 is the primary interface for my DMZ. I want WAN1 to be able to fail over to WAN2. I want traffic originating in DMZ to always go out WAN2.
Everything seems to be working as expected except for LAN to DMZ access. I can't seem to figure out the right voodoo. I suspect a NAT problem, but I've been unable to figure it out so far. Or it could be my DMZ out to WAN2 hack.
Any suggestions would be greatly appreciated.
     Greg
Hehe, I seem to do this to myself a lot. In the process of writing the post, I guessed that it could be the DMZ to WAN2 route that was causing the LAN to DMZ problem. Turns out when I disabled that route-map, the LAN worked.
So, my question has changed to how can I create a route-map for the DMZ such that all traffic goes out WAN2 except for the traffic which should be going back to the LAN?
     Greg
Okay, looks like I found my solution:
! don't want to route local traffic out WAN2
ip access-list extended dmz-to-wan
  deny   ip 192.168.2.0 0.0.0.255 172.25.36.0 0.0.0.255
  permit ip any any
route-map dmz-map permit 10
  match ip address dmz-to-wan
  set ip next-hop xxx.xxx.xxx.174
Too bad I can't mark my own question as answered ;-)
Thanks to those to took the time to read my question.
