???intervlan on catalyst 2950 with 2600 router???
Jul 27th, 2010
Hi All,
I´m trying build a very simple scenary using intervlan routing with a router 2621XM with a Catalyst 2950.
My router is connected using fastethernet 0/1 to the fastethernet 0/2 on switch.
Link lights are up, but still can´t get access from router to the switch and can´t see at CPD command as well.
Follow the configuration to both equipments :
Router
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip address 10.1.1.1 255.255.255.0
interface FastEthernet0/1.400
encapsulation dot1Q 400
ip address 10.1.4.1 255.255.255.0
interface FastEthernet0/1.500
encapsulation dot1Q 500
ip address 10.1.5.1 255.255.255.0
Switch
switch_lab#sh start
Using 1663 out of 32768 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname switch_lab
ip subnet-zero
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
vlan 400
name data
vlan 500
name voice
interface FastEthernet0/2
switchport mode trunk
interface FastEthernet0/3
interface FastEthernet0/4
switchport access vlan 400
switchport mode access
switchport voice vlan 500
spanning-tree portfast
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
ip address 10.1.1.2 255.255.255.0
no ip route-cache
interface Vlan400
ip address 10.1.4.2 255.255.255.0
no ip route-cache
shutdown
interface Vlan500
ip address 10.1.5.2 255.255.255.0
no ip route-cache
shutdown
ip http server
line con 0
line vty 5 15
end
Does can somebody explain or help to get way to sort out it ??
AB
Antonio Brandao Tue, 07/27/2010 - 04:00
i don´t now why, but is working now I just moved on router
from FE 0/0 to FE 0/1 and worked.
I think is some think on 2600 router series that don´t let me do it using FE 0/0
Thanks a lot
AB
Leo Laohoo Tue, 07/27/2010 - 15:35
That's because your dot1q trunking configuration for your router are all in Fa 0/1 while Fa 0/0 is also "shutdown".
Antonio Brandao Wed, 07/28/2010 - 00:56
Sorry ,
Did some mistake while wrote previous post.
If I try same configuration using FE 0/1 will not work, but using FE 0/0 works fine.
Thats the conf is working now
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address 10.1.2.1 255.255.255.0
Thks
Antonio
Related Content
