ASA Multiple context in Multiple Mode
Answered Question
Jul 27th, 2010
Is it possible to configure an ASA context in routed mode and another Context in transperent mode ?
Correct Answer by johuggin about 6 years 8 months ago
Good question!
From the Command reference for 8.3 for the 'firewall transparent' command:
http://www.cisco.com/en/US/partner/docs/security/asa/asa83/command/reference/ef.html#wp2016768
The quote is the same in the 8.0 and 8.2 command references.
Usage Guideline
For multiple context mode, you can use only one firewall mode for all  contexts. You must set the mode in the system configuration. This  command also appears in each context configuration for informational  purposes only; you cannot enter this command in a context.
So, unfortunately, it looks like the answer is no. Hope this answers your question!
-Joe
Overall Rating: 5 (1 ratings)
Correct Answer
johuggin Tue, 07/27/2010 - 07:03
Good question!
Usage Guideline
-Joe
Trending Topics - Security & Network
