Translation rule question
Jul 27th, 2010
I have translation rule like this below, i understand the rule that replaces the first digit 9 with 4 what is the significance of \1 at the end , I see in some rules it is \3 , \2 etc i am not able to corelate that to anything. May be a silly one but can anyone answer soon as we have a number change in Qatar.
rule 1 /^9\(.*)/ /4\1/
Thx
Aji N C
Essam Lutfi Tue, 07/27/2010 - 03:30
rule 1 /^9\(.*\)/ /4\1/
\1 means the first group which is (.*) in this case.
/ ^9  \(.*\) /     as you understood the first part correctly, the second part is grouping all the coming numbers after 9 and make it a group.
/  4   \1   /      then in the translation as you mwntioned replace 9 with 4 and then follow the 4 with the Group 1 which you previously determined in the first part of your rule.
i hope that this will help you.
