Compliance management question
Jul 27th, 2010
Dear,
I am trying to get all ports on devices with the following specs :
+ macro description vi
- authentication periodic
The strange thing is that RME takes only one of the 2 lines, how do I configure
RME so I have all the ports with the macro commando and without the authentication commando ?
Many thanks,
Lieven Stubbe
NMBS
lni1 Tue, 07/27/2010 - 04:40
My mistake :
CLI commands conditional block : + macro description vi
CLI Compliance block : + authentication periodic
Joel Monge Tue, 07/27/2010 - 08:32
Based on your last update, you want to add "authentication periodic" only on interfaces that contain "macro description vi".  If so, this should do it:
Conditional Block:
Name: DefaultPreReq     SubMode: Yes      isPrerequisite: Yes
Ordered : No     Prerequisite-Commandset : none     Parent: none
  [#interface.*#]
Compliance Block:
Name: Commands     SubMode: Yes      isPrerequisite: No
Ordered : No     Prerequisite-Commandset : DefaultPreReq     Parent: none
  [#interface.*#]  (Using   the   submode   of   conditional   commands   above)
