Identification of VPN aware PEs
arun kumar Tue, 07/27/2010 - 04:26
One way is to execute "show ip bgp vpnv4 vrf " in any of the PE router where vrf is configured. This will display the VRF routes and the corresponding PE router ip address in next hop field.
prefix     next-hop     bgp attributes
Regarding the interfaces in other PE routers for a VRF i doubt there is not any CLI exist in a remote PE router.
Giuseppe Larosa Wed, 07/28/2010 - 13:04
Hello Mohsin,
you can use
sh ip vrf detail
but VRF name can be meaningful or not you need to look at also at route targets values
import: what VPNv4 prefixes are learned from signalling plane and imported as IPv4 routes in this specific VRF
export: how routes of this site are advertised to other PE nodes
also as suggested by Arun, but I use the following variant
sh ip bgp vpnv4 all
it shows you if the prefix is imported in a local VRF table (you will see a second section, a first section is the vpvn4 prefix), if it is the PE VRF is part of the VPN otherwise it is not.
Hope to help
