isakmp key address no-xauth
Jul 27th, 2010
What is the equivalent of this on an ASA?  thanks again
whanson Tue, 07/27/2010 - 05:36
Thanks but now a new question if you do that then do you need the pre-share key definition under the tunnel or do you still need that.
Rahul Govindan Tue, 07/27/2010 - 05:40
If you use the command,  automatically a tunnel group type-l2l is created with the name as the address and the pre-shared key inserted.
whanson Tue, 07/27/2010 - 06:29
One last question, if that command creates the tunnel definition then is no-xauth the default anyway for site to site?
