Error message
  • Unable to create CTools CSS cache directory. Check the permissions on your files directory.
Tracing Locations
Jul 27th, 2010
Can anyone point me in the right direction to trace the Locations. I have a centralized call manager 6.1 with multiple branches. The calls between the branches are controlled via the Location mechanism. I can monitor each branch bandwidth available and calls in progress via Real Time Monitor. From this I can see multiple calls on one of the branches but dont know whats using this bandwidth. What trace can I run to see what device is clocking up the Location count.
regards
Dave
Jaime Valencia Tue, 07/27/2010 - 06:17
  • Cisco Employee,
  • Hall of Fame,
    2011
CUCM detailed traces have this info, they will show the allocation/de-allocation for each call as it's made or someone hangs the call. It will show how much BW is allocated and how much is left available.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
dbudden Tue, 07/27/2010 - 23:12
Thanks for the responce.
Is this the CM Services - Cisco CallManager trace. If so I cant find the location details within the trace.
regards
Dave
Jaime Valencia Wed, 07/28/2010 - 08:12
  • Cisco Employee,
  • Hall of Fame,
    2011
The info is there, make sure you're gathering DETAILED traces.
Search for location or for the name of the location within the trace
java
