Help setting up a SPA9000
Jul 27th, 2010
I have recently purchased a SPA9000 to replace the call manger on one of our vessels as during the yard stay they do not wish to pay the rates.
I purchased this as a means for the crew to make internal calls throughout the vessel only but I cannot get the setup wizard to work and was wondering if I could get some directions on how to set this up manually for 10 Cisco VOIP phones
Rhanks
Neil
Adrian Saavedra Tue, 07/27/2010 - 07:00
  • Gold, 750 points or more
Hello Neil,
A couple of months ago I was configuring one SPA9000. It was very stressful to work with that wizard. I was running the latest version of the wizard in Win XP Service Pack 2. Then a coworker discovered that the wizard started working relatively well in Win XP Service Pack 3. Just an idea, I thought that could be helpful to you.
Hope it helps, please rate if it does.
Kind regards,
- Adrian.
