07-27-2010 05:14 AM - edited 03-04-2019 09:12 AM
Hi Experts,
Just stuck in providing solution.
Having two 1841 with parallel point-to-point serial links.
Third BRI/ISDN link.
Requirement : Serial-1 should be used as primary and in case of serial-1 fails serial-2 should take over and in case both serial goes down BRI should dial out and go through.
Please help m just clueless.
Thanks in Advance.
Saurabh Joshi
07-27-2010 05:38 AM
Saurabh
There is a simple solution assuming that the serial links are strict point to point interfaces (such as HDLC or PPP). It may be more complex if they are something like Frame Relay.
I would suggest configuring a primary static route specifying the next hop of serial-1, configure a floating static specifying the next hop of serial-2, and another floating static (with even higher distance) specifying the next hop of the BRI. It might look something like this:
ip route 0.0.0.0 0.0.0.0
Rick
07-27-2010 05:40 AM
I have this in my mind already.
The problem is the BRI should dian only in case both the serial link goes down.
Like a Back-up dialer interface.
Thanks for the reply.
07-27-2010 05:53 AM
Saurabh
And if you configure as I suggest you will get the result that BRI only dials if both serial links are down.
In normal operation the static route with no weight is used. If serial-1 goes down then that static route is removed from the route table and the static route with weight 240 is used (traffic is on serial-2). If serial-1 is down and then serial-2 goes down then that static route with weight 240 is removed from the route table and the static route with weight 250 is used.
Rick
07-27-2010 05:56 AM
Ok thanks i will give shot to it.
