ATA 186 & UTP cable distance
abhasjain
ATA 186 is connected to a CIsco switch & hangs frequently. The distance between ATA & CIsco Switch is more than 70 m.
Is there any specification for supported distance between Cisco switch & ATA 186 ?
Abhas Jain
Brandon Buffin
Maximum length for ethernet cable is 100 meters (328 feet). Doesn't sound like you're over the max. Have you tried upgrading the firmware? Using another ATA at the same location?
Brandon
I even tried placing IP phone & another ATA 186 at that location but faced same problem. What can be the issue ?
Abhas Jain
Have you tested the cable run? Tested/changed patch cables on each end?
Brandon
