C2960 with RADIUS
Answered Question
Jul 27th, 2010
Hello, everyone!
I have a problem with dynamic VLAN assignment. The setup is basically the following:
Host - Switch - RADIUS Server
I have no problem authenticating, messages get through without any problems.
The thing is the switch doesn't seem to notice the additional info the RADIUS server provides, e.g. the [64] Tunnel-Type, [65] Tunnel-Medium-Type, and [81] Tunnel-Private-Group-ID.
Here is my sw configuration and some radius configuration
Current configuration : 1795 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication dot1x default group radius
aaa session-id common
system mtu routing 1500
ip subnet-zero
dot1x system-auth-control
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/2
switchport mode access
dot1x pae authenticator
dot1x port-control auto
dot1x violation-mode protect
interface GigabitEthernet0/3
interface Vlan1
ip address 10.2.1.4 255.255.255.0
no ip route-cache
ip http server
ip http secure-server
radius-server host 10.2.1.2 auth-port 1812 acct-port 1813
radius-server key testing123
control-plane
end
The VLANs are:
VLAN Name                             Status    Ports
1    default                          active    Gi0/1, Gi0/2, Gi0/3, Gi0/4
                                                Gi0/5, Gi0/6, Gi0/7, Gi0/8
                                                Gi0/9, Gi0/10, Gi0/11, Gi0/12
                                                Gi0/13, Gi0/14, Gi0/15, Gi0/16
                                                Gi0/17, Gi0/18, Gi0/19, Gi0/20
                                                Gi0/21, Gi0/22, Gi0/23, Gi0/24
2    MAN                              active
3    GRE                              active
4    BLU                              active
13   GUEST                            active
99   NATVIE                           active
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
The RADIUS user is:
userc   Cleartext-Password := "pass3"
        Service-Type = Framed-User,
        Tunnel-Medium-Type = "802",
        Tunnel-Type = "VLAN",
        Tunnel-Private-Group-Id = "GRE"
IOS Version 12.2(44)SE6
As you see, it's a pretty standard configuration and although the authentication itself works, the dynamic VLAN assignment doesn't.
Any ideas on what might solve the problem?
Correct Answer by Javier Henderson about 6 years 10 months ago
Add the following to your configuration and test again:
aaa authorization network default group radius
Overall Rating: 5 (1 ratings)
Correct Answer
Javier Henderson Tue, 07/27/2010 - 08:51
  • Cisco Employee,
incotexbg Wed, 07/28/2010 - 01:11
Thank you very much for pointing that out!   We have it working finally!
For anyone reading and searching the net on this topic, here's what works for me:
The FreeRADIUS Server is mostly with its default settings, apart from the things you have to change in order for mschapv2 authentication to work and this:
eap.conf -> copy_request_to_tunnel = yes
clients.conf -> client 10.2.1.4 {
                                                secret = somesecret
                                                shortname = blah_blah
                                                nastype = cisco
users ->         user   Cleartext-Password := "pass"
                                 Tunnel-Medium-Type = "IEEE-802",
                                 Tunnel-Private-Group-Id = 2
For the 'Tunnel-Private-Group-Id' attribute you can supply either the number of the VLAN or its NAME. It's case-sensitive and be sure to add the VLAN     manually (or via VTP) to the switch before attempting dynamic assignment. The Tunnel-Medium-Type I use IEEE-802. Just "802" does not work, contrary to some internet articles.
For the IOS c2960-lanbasek9-mz.122-44.SE6, I use the following info:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/sw8021x.html#wp1025133
all the way down to 'Configuring the Host Mode'. I had to enable the VSA functions or whatever it is with the radius-server vsa send authentication.
For the IOS c2960-lanbasek9-mz.122-53.SE2 I use this:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_53_se/configuration/guide/sw8021x.html#wp1025133
Thanks again and happy networking!!
