Dual home routers
Jul 27th, 2010
I have several 28XX and 38XX routers deployed. I want to dual connected them to my Core switches. Should I configure them as two different layer 3 subnets and let my internal routing protocol EIGRP load balance or should I configure the two interfaces on the routers as a bridge group and leave them on the same subnet as the network?
Nagaraja Thanthry Tue, 07/27/2010 - 06:13
  • Cisco Employee,
I would suggest using different IP subnets and letting routing protocol
handle the load balancing. If you bridge the interfaces, there is a chance
that you create a loop in the network. Also, if it is bridged, the
interfaces will participate in spanning-tree calculations. So, every time
some change occurs in the network, your router interfaces could be down for
about 30 seconds (spanning-tree calculation time).
Hope this helps.
NT
