Dual WAN router with SSL VPN unreachable for clients
Answered Question
Jul 27th, 2010
I have a Cisco 888 configured in a Dual WAN setup. There is an ADSL link connected to VLAN 100 and a SDSL link connected to Dialer0. The customer wants to use the ADSL link for normal browsing and wants external SSL VPN users to terminate on the SDSL link. I tried to configure the SDSL link as failover for the ADSL connection.
What's working:
- Internet access for the local clients
What's not working:
- Failover of the ADSL link to SDSL.
- SSL VPN access for clients. Surfing to the external IP address only results in a default HTTP page. Specifying /webvpn.html results in a 404 not found error.
Here's my configuration:
version 15.0
no service pad
hostname x
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 x
aaa new-model
aaa authentication login sslvpn local
aaa session-id common
memory-size iomem 10
crypto pki trustpoint TP-self-signed-3964912732
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3964912732
revocation-check none
rsakeypair TP-self-signed-3964912732
crypto pki certificate chain TP-self-signed-3964912732
certificate self-signed 03
  x
      quit
ip source-route
ip dhcp excluded-address 192.168.10.254
ip dhcp excluded-address 192.168.10.10 192.168.10.20
ip dhcp pool ccp-pool
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.254
   dns-server 213.75.63.36 213.75.63.70
   lease 0 2
ip cef
no ip domain lookup
ip domain name x
no ipv6 cef
license udi pid CISCO888-K9 sn x
username ciscoadmin privilege 15 secret 5 x
username vpnuser password 0 x
controller DSL 0
mode atm
dsl-mode shdsl symmetric annex B
interface Loopback1
description SSL dhcp pool gateway address
ip address 192.168.250.1 255.255.255.0
interface Loopback2
description SSL VPN website IP address
ip address 10.10.10.1 255.255.255.0
ip policy route-map PBR_SSL
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
load-interval 30
no atm ilmi-keepalive
pvc KPN 2/32
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
switchport access vlan 100
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
description LAN
ip address 192.168.10.254 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1300
interface Vlan100
description KPN ADSL 20/1
ip address dhcp
ip nat outside
interface Dialer0
description KPN SDSL 2/2
ip address negotiated
ip access-group INTERNET_ACL in
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp pap sent-username x password 0 x
no cdp enable
ip local pool sslvpnpool 192.168.250.2 192.168.250.100
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat pool SSLVPN-to-SDSL 10.10.10.1 10.10.10.1 netmask 255.255.255.0
ip nat inside source static tcp 10.10.10.1 443 interface Dialer0 443
ip nat inside source static tcp 10.10.10.1 80 interface Dialer0 80
ip nat inside source route-map NAT_ADSL interface Vlan100 overload
ip nat inside source route-map NAT_SDSL pool SSLVPN-to-SDSL overload
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip route 0.0.0.0 0.0.0.0 Dialer0 10
ip access-list extended INTERNET_ACL
remark Used with CBAC
permit icmp any any unreachable
permit icmp any any packet-too-big
permit icmp any any time-exceeded
permit tcp any host 92.64.32.169 eq 443 www
deny   ip any any log
ip access-list extended LAN
permit ip 192.168.10.0 0.0.0.255 any
deny   ip any any
dialer-list 1 protocol ip permit
no cdp run
route-map NAT_SDSL permit 10
match ip address LAN
match interface Dialer0
route-map NAT_ADSL permit 10
match interface Vlan100
route-map PBR_SSL permit 10
set interface Dialer0
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
transport input telnet ssh
scheduler max-task-time 5000
webvpn gateway MyGateway
hostname d0c
ip address 10.10.10.1 port 443
http-redirect port 80
ssl trustpoint TP-self-signed-3964912732
inservice
webvpn install svc flash:/webvpn/anyconnect-dart-win-2.5.0217-k9.pkg sequence 1
webvpn install svc flash:/webvpn/anyconnect-macosx-i386-2.5.0217-k9.pkg sequence 2
webvpn install svc flash:/webvpn/anyconnect-macosx-powerpc-2.5.0217-k9.pkg sequence 3
webvpn context SecureMeContext
title "SSL VPN Service"
secondary-color #C0C0C0
title-color #808080
ssl authenticate verify all
login-message "VPN"
policy group MyDefaultPolicy
   functions svc-enabled
   svc address-pool "sslvpnpool"
   svc keep-client-installed
default-group-policy MyDefaultPolicy
aaa authentication list sslvpn
gateway MyGateway
inservice
end
Any suggestions on where to look?
Correct Answer by mulatif about 6 years 7 months ago
This works for me. When client is trying to resolve the fqdn for domain as specified in "svc split dns.." it will contact the DNS server assigned through the Tunnel. For all other queries , it contacts the DNS outside the Tunnel.
You can run a packet capture on the Physical interface on the Client to see the DNS query leaving ?
Also in some home routers, the DNS is assigned as the Router itself (which usually is 192.168.X.X address), so you want to make sure that DNS server being assigned is not part of the Split Tunnel.
Naman
mulatif Wed, 07/28/2010 - 09:56
  • Cisco Employee,
The possible issue here could be Asymmetric routing. So your Outside clients are connecting to the Dialer 10 interface but since your Default Route is through the other interface, so  return traffic is not leaving through dialer interface.
I would suggest to take this in two steps
1. Test with one Remote PC and add "ip route.." for that PC's Public IP to leave through Dialer 10.
2. Make sure it works. If it doesn't then you need to focus on the WebVPN part to see what could be wrong. However if this works then it proves WebVPN config is Ok.
3. Now remove the route in Step 2 and you will need to configure a Local Policy for the Router generated traffic (ip local policy
sandervanloosbroek Tue, 08/03/2010 - 09:48
I solved one piece of the puzzle:
hostname d0c
This is wrong as it should hold the EXTERNAL IP address instead of the internal one. That fixed the WebVPN over the ADSL line. Now all that remains is fixing the routing and making sure the internet connection continues to work even when the VPN is active. For some reason the AnyConnect client applies a default route of 0.0.0.0 to all clients.
To be continued...
mulatif Tue, 08/03/2010 - 10:03
  • Cisco Employee,
By default , AnyConnect client uses "Full Tunneling" , which means all traffic needs to go through the Router. If you only want specific traffic to be sent through the AnyConnect client then use "Split-Tunneling", which can be configured as below
webvpn context X
policy group Y
  svc split include
  svc split include
Naman
sandervanloosbroek Wed, 08/04/2010 - 05:48
good tip Naman, the route is now being shown correctly in the connection details but traffic to the internet despite the correct route is still impossible. These are the connection statistics:
Protocol Info
    Active Protocol
        Protocol Cipher:  RSA_AES_128_SHA1
        Protocol Compression:  None
        Protocol State:  Connected
        Protocol:  TLS
Routes
    Secure Routes
Firewall Rules
Am I missing something common? It is my first WebVPN setup (used to do EasyVPN). Thanks for your help.
mulatif Thu, 08/05/2010 - 07:37
  • Cisco Employee,
Below shows that 'only' traffic to 192.168.10.X network is being sent through the AnyConnect tunnel and all Internet traffic will leave through the local connection. So the only other reason I can think is that you are not assigning the user a correct DNS Server Address ?
The DNS Server is assigned using
webvpn context X
policy group Y
   svc dns-server primary
   svc dns-server secondary
Make sure that the DNS server you assign is reachable and can resolve names.
You can also make sure that its actually a DNS issues by trying to "ping 4.2.2.1" as a test for the client PC.
Naman
sandervanloosbroek Thu, 08/05/2010 - 08:01
I found out what was wrong 15 minutes ago, I activated an ACL in that policy as well that was conflicting. After I removed that the split tunnel worked flawlessly except for the DNS problem you also pointed out. Instead of pointing to a DNS server I would like the VPN clients to use their own DNS and not resolve anything through the gateway. I tried the following:
title "VPN Service"
secondary-color orange
title-color black
login-message "VPN"
   svc split dns "theirdomain.local"
   svc split include 192.168.x.0 255.255.255.0
gateway MyGateway
inservice
This doens't seem to work, do you have any other suggestions?
Correct Answer
mulatif Thu, 08/05/2010 - 09:14
  • Cisco Employee,
Naman
sandervanloosbroek Thu, 08/05/2010 - 10:55
It works for me too but only with the AnyConnect client on Windows. The Mac version of AnyConnect does not receive/interpret the split-dns command or so it seems so I'm stuck halfway. I might open a TAC for this as the setup does work correctly.
sandervanloosbroek Thu, 08/05/2010 - 14:02
Just got a reply from Cisco, this  is a confirmed bug [CSCtf20226] in Mac OS X 10.6. Their workaround is to  explicitly define external DNS servers. I used the Google public DNS  servers and this indeed works as expected.
(config-webvpn-group)#svc dns-server primary  8.8.8.8
(config-webvpn-group)#svc dns-server secondary  8.8.4.4
Now all I need to do is fix routing the VPN traffic over the other interface.
sandervanloosbroek Wed, 09/22/2010 - 05:29
With the help of user halijenn I have been able to solve the dual WAN problem. It turns out that the WebVPN interface *NEEDS* to be terminated on the default gateway or else it will not work. The obvious workaround is to make a route-map for all traffic except the WebVPN traffic so the default gateway can be set to the secondary interface and the WebVPN will work. I've posted my full config for anyone who ran into the same problem.
I've had stability problems (WebVPN would stop working) with the latest 15.1-2T1 version and downgraded to 15.0-1M3. I've also upgraded to the latest AnyConnect client (2.5.0.1025).
Thanks everyone who helped me.
S.
Current configuration : 6478 bytes
version 15.0
no service pad
hostname xxx
boot-start-marker
boot system flash:c880data-universalk9-mz.150-1.M3.bin
boot-end-marker
aaa new-model
no ip source-route
   import all
   dns-server 213.x.x.x 213.x.x.x
   lease 0 2
ip cef
no ipv6 cef
license udi pid CISCO888-K9 sn FCZ1426C1EX
controller DSL 0
mode atm
interface Loopback1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface ATM0
no ip address
load-interval 30
interface ATM0.1 point-to-point
pvc 2/32
interface Vlan1
description LAN
ip nat inside
ip tcp adjust-mss 1452
ip policy route-map NonSSLOut
interface Vlan100
ip address 188.x.x.67 255.255.255.248
ip nat outside
interface Dialer1
ip address 92.x.x.x 255.255.255.248
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 2
ppp authentication pap callin
ppp pap sent-username xxx password 0 xxx
no cdp enable
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface Vlan100 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended LAN-only
deny   ip 192.168.10.0 0.0.0.255 192.168.250.0 0.0.0.255
access-list 10 permit 192.168.250.0 0.0.0.255
access-list 100 permit ip 192.168.10.0 0.0.0.255 any
dialer-list 2 protocol ip permit
no cdp run
route-map NonSSLOut permit 10
match ip address LAN-only
set ip default next-hop 188.x.x.x
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
privilege level 15
ip address 92.x.x.x port 443
inservice
webvpn install svc flash:/webvpn/anyconnect-win-2.5.1025-k9.pkg sequence 1
webvpn install svc flash:/webvpn/anyconnect-macosx-i386-2.5.1025-k9.pkg sequence 2
webvpn install svc flash:/webvpn/anyconnect-macosx-powerpc-2.5.1025-k9.pkg sequence 3
   svc split include 192.168.10.0 255.255.255.0
gateway MyGateway
inservice
end
