07-27-2010 07:22 AM - edited 03-06-2019 12:12 PM
hi
i have 1 stack of 4x 3750 switches with a data and voip vlan (vlan3 and vlan 33)
i recently purchased 2x 2960s switches which are stacked and have 2 vlans (vlan3 and vlan103)
vlan 103 is for iscsi/san storage
I would like to connect ports 1/0/1 and 2/0/1 (vlan3) of the 2960s switches to port 1/0/1 and 2/0/1 of the 3750 stack (just to clarify i do not want to stack these together but just connect them using an ethernet cable and by connecting 2 cables have a redundant setup)
i only want vlan3 traffic to go between the 3750 and 2960 switches and none of the other vlans
how do i configure each of the ports on the 2960s and the 3750 to make this work. i have read the 2960s admin guide but i could not figure this out
many thanks for your help
cheers
07-27-2010 08:25 AM
Connect the switches together and put both links in each switch in an Etherchannel. If you only want vlan 3 to go over it, then you don't need to trunk the Etherchannel.
Refere to this document for configuring L-2 etherchannel
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_configuration_example09186a0080094647.shtml
Reza
08-03-2010 06:19 AM
hi
thanks for the link
i have done some reading on this (chapter 35 for 3750 and 37 for 2960) and found some interesting insights and configured the switches and connected them but nothing happens at all, the interfaces stay down (line as well)
i have pasted the relevant config of both the 3750 and the 2960 switch and perhaps you can see the obvious thing i am doing wrong here
3750 config
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
interface GigabitEthernet1/0/1
description switch_2960-1/0/1
switchport access vlan 3
switchport mode access
speed 1000
duplex full
channel-group 1 mode on
spanning-tree portfast
spanning-tree bpduguard enable
interface GigabitEthernet1/0/2
description switch_2960-2/0/2
speed 1000
duplex full
interface GigabitEthernet2/0/1
description switch_2960-2/0/1
speed 1000
duplex full
interface GigabitEthernet2/0/2
description switch_2960-1/0/2
speed 1000
duplex full
interface Vlan1
no ip address
shutdown
interface Vlan3
ip address 10.3.1.3 255.255.0.0
ip broadcast-address 10.3.255.255
ip classless
ip route 0.0.0.0 0.0.0.0 10.3.1.1
ip http server
ip http secure-server
control-plane
2960 config
description switch_3750-1/0/1
speed 1000
duplex full
description switch_3750-2/0/2
speed 1000
duplex full
description switch_3750-2/0/1
speed 1000
duplex full
description switch_3750-1/0/2
speed 1000
duplex full
interface Vlan1
no ip address
shutdown
interface Vlan3
ip address 10.3.1.4 255.255.0.0
ip default-gateway 10.3.1.2
ip http server
ip sla enable reaction-alerts
i went for the channel-group mode on as this seems to be the easiest to configure (as long as you make sure it is in the same vlan, speed, duplex etc) which i think it is,
the only difference i can see is the 3750 has this configured on the ports
and the 2960 hasn't.
the consultants that came in when installing the 3750 configurd all the ports with this
when i connect the 2 switch stacks via the ehterchannel ports no lights come on the switch at all (using a straight thru cable btw but also tried crossover) but nothing happens
when i do a show interfaces gigabitEthernet 1/0/1 on the 3750 i get the following:
GigabitEthernet1/0/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 0023.5d83.be81 (bia 0023.5d83.be81)
Description: switch_2960-1/0/1
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
Media-type configured as connector
input flow-control is off, output flow-control is unsupported
Last input 5w1d, output 3w4d, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
7997664 packets input, 2176348526 bytes, 0 no buffer
Received 47574 broadcasts (0 multicasts)
0 runts, 1 giants, 0 throttles
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 26538 multicast, 0 pause input
28174176 packets output, 33210654757 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
and this is the output from the 2960
Hardware is Gigabit Ethernet, address is 1c17.d3f4.8f81 (bia 1c17.d3f4.8f81)
Description: switch_3750-1/0/1
Last input 1w0d, output 1w0d, output hang never
770 packets input, 85015 bytes, 0 no buffer
Received 98 broadcasts (29 multicasts)
0 watchdog, 29 multicast, 0 pause input
893 packets output, 556254 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
is there anything obvious i am doing wrong here?
many thanks
08-03-2010 06:24 AM
What kind of cable you are using to connect these two interfaces? Can you
try a crossover cable and see if that helps? Also, you do need to remove
"spanning-tree bpduguard enable" from the interfaces as they would force the
ports to go errdisabled.
Hope this helps.
NT
08-03-2010 06:31 AM
i have tried both crossover and straight thru cable, makes no difference
also removed the spanning-tree portfast and spanning-tree bpduguard enable from the interface but does not make a difference
no lights come on on either end and the interfaces remain down.
08-03-2010 06:43 AM
This seems more like a physical layer issue. Can you try setting the
speed/duplex to auto on both ends?
interface gi 1/0/1
speed auto
duplex auto
Also, if you are using any patch panels, please bypass them and see if you
get the link.
Hope this helps.
NT
08-03-2010 05:38 PM
If both switches are connected using copper, then why not use the "test cable tdr" function of both? This will validate if you indeed have a cable problem or not.
08-04-2010 03:48 AM
the 2 switches are connected directly with 4x straigh thru ethernet cables
i ran the tdr tests and everything is showing up as normal
only difference is that the 3750 reports the length to be +- 4 meters and the 2960 +-0 meters
Interface Speed Local pair Pair length Remote pair Pair status
Gi1/0/1 1000M Pair A 1 +/- 0 meters N/A Normal
Pair B 2 +/- 0 meters N/A Normal
Pair C 2 +/- 0 meters N/A Normal
Pair D 2 +/- 0 meters N/A Normal
Gi1/0/1 1000M Pair A 2 +/- 4 meters N/A Normal
Pair B 2 +/- 4 meters N/A Normal
Pair C 2 +/- 4 meters N/A Normal
Pair D 2 +/- 4 meters N/A Normal
as i have a support contract with the company that did the installation they are testing this in their lab and will get back to me with any changes i need to make, i will report back as soon as i hear from them
cheers!
10-20-2010 08:24 AM
Did you check the status of the STP? Maybe you have to do an extra config on the 3750 to get the channel up and running.
I had strange issues when connecting 2 3750 stacks together with a channel master-master slave-slave, but they work now....
Try switching off any 'optional' features on the ports when setting up the channel, and when connected, work your way 'up'
Quirijn
10-25-2010 03:17 AM
hi
i could not get it to work with straight thru cables and when i tried with a cross over cable it initially did not work either, until i bought 4 brand new crossover cables and now it is working fine.
there must have been some cabling fault in the crossover cable because with the brand new ones it is working fine and i have a 4gb connection between the 2 servers.
cheers
11-22-2010 02:23 AM
quick comment..... on the 3750 you have 'port-channel 1' interface defined - because the
IOS will make a dumb config for it when you assign an interface to that channel-group if it
doesnt exist... .however, you dont have a port-channel defined on the 2960s - so those
interfaces are tagged to a virtual interface that doesnt exist. define the port-channel interface
on the 2960 and it should spring to life.
alan
