07-27-2010 07:32 AM
I configured FTP LB, but when I try to enter the VIP via FTP or through a Telnet to port 21 I see the following error:
C:\>telnet 10.1.2.65 21
530 Connection refused, unknown IP address.
421 Service not available, closing control connection.
Se ha perdido la conexión con el host.
C:\>ftp 10.1.2.65
Conectado a 10.1.2.65.
Conexión cerrada por el host remoto.
I think the configurations are correct:
rserver host galileo_3_www
ip address 10.4.2.4
inservice
serverfarm host ADMIN1
rserver galileo_2_www
inservice
class-map match-all VIP-Admin1
2 match virtual-address 10.1.2.65 tcp range 23 65535
class-map match-all VIP_Admin1
2 match virtual-address 10.1.2.65 any
class-map match-all VIP_Admin1-FTP
2 match virtual-address 10.1.2.65 tcp range 20 22
policy-map type loadbalance first-match ADMIN1
class class-default
serverfarm ADMIN1
policy-map multi-match POLICY
class VIP_Admin1-FTP
loadbalance vip inservice
loadbalance policy ADMIN1
nat dynamic 1 vlan 2
inspect ftp
class VIP-Admin1
inspect ftp
class VIP_Admin1
service-policy input POLICY
Jaime.
07-28-2010 04:03 AM
Should work.
Get a sniffer trace on the server and see what is going on.
Did you try directly to the server ?
Gilles.
07-28-2010 06:01 AM
Thanks Glen, the problem was the server. I had to enable security policies in the server to accept connections of IP NAT that performs ACE.
Now, it works fine.
Jaime
