how to configure 3620 router to redirect public port 8080 to inside local port 80?
Jul 27th, 2010
I manage a small net work on a boat.
We use a router to manage the internet connection via different interfaces. eg Satellite Internet on fa0/1, Landbased Wi-fi fa1/0 etc. The boat's network is split into 3 VLANS.
We have a new peice of equipment onboard that monitors enginroom machinary. It has a static IP address and is connected to VLAN2.
I need to configure port forwarding so that this equipment can be accessed from ther internet for monitoring purposes...the public port being 8080 and the local being 80.
I have already been kicked off twice by the router for incorrect commands, and would appreciate some detailed command lines to fix the problem.
I attach the show run configuration.
Thanks in advance
Related Content
