Call Recording Idea Using Cisco Unity
tjkreutz_1
Hi There,
I'm was wondering if anyone has thought of or is currently employing Unity as a call recording server,  I have a secure call recording requirement for a contact center application (CUCCE) as well as some E911 phones.  Current market surveys has revealed that secure VoIP call recording is not a product. However, company's like Telstrat are working on it.
In the mean time, I thought of using CUCM 8.0(2) or greater, and was thinking of potentially experimenting with the built in phone bridging function to allow the bridging of active phone calls directly to Unity.  Unity signaling and media in transit can be secured using TLS and SRTP. Additionally, Unity media at rest can also be encrypted.  Therefore, if Unity can successfully be integrated to accept these bridged calls via a separate Voice Mail Pilot DN and we can allocate enough voice mail ports and backend exchange message store disk space, we might have our own secure call recording solution.
Any thoughts pro or con on this idea are graciously requested.
David Hailey
So my first thought is I'm curious to know how you envisioned this working.  The Barge (built-in bridge) and cBarge functions only work for shared lines.  In order for them to work, they would have to be invoked by another party - so, for instance:
Tom and Sue share x1001
Tom receives a call
Sue must invoke Barge or cBarge and Privacy must be disabled for the feature to work
So, if you're planning to use Unity for this - what did you think the setup would look like?
FYI - I'm not being critical of your idea.  I thought you might want to bounce this off some other minds so I'm just getting the conversation started.
Hailey
Hi David,
Thanks so much for the response.
Thanks for the Barge and cBarge functional info. too. I was not aware of the
actual operation of those functions, but was planning to investigate the
bridging function contained on the phones to see if it could be used the way
that I envisioned. Based on your response, it sounds like the phone bridging
function may not work as I was anticipating. Perhaps some form of special call
forwarding may be an option or may need to be designed?
The idea is only conceptional. The Cisco solution design, if even currently
possible, may be implemented using whatever features are available in CUCM and
Unity that ultimately produces the desired end solution. Then again, this idea
may not be feasible unless some custom design and/or scripting is applied.
Basically, the idea is to be able to redirect the secure audio (SRTP) stream
from any VoIP endpoint to a recording server (e.g. Unity in this case).
Currently, there is no such COTS solution available on the market. Here's what
I was thinking.
Call Recording Scenarios
1. User A on phone A calls Phone B, and User B on phone B answers the call, the
Call in Progress must be recorded locally.
2. User A on phone A calls Phone B, and User B on phone B answers the call,
while the call is simultaneously routed to the PSAP via the PSTN GWY., and again
the Call in Progress must be recorded locally.
We need to fork/fwd the call from Phone B, while User B is still active on the
Call to a Unity Voice Mail port, so the call can be recorded simultaneously.
This is where the bridge idea come in. In effect a three/four way call could
exist. Secure conference resources can also be made available, if they could be
leveraged for a larger conference bridge.
Note: We have some weird 911 requirements where our 911 calls need to be routed
to the PSAP via PSTN GWY and also forked to several NOC 911 phones for local
monitoring and recording. As far as I know, this hasn't been done before, and
I'm currently in the architecture phase.
I am fully aware that there may not be a COTS solution to this requirement, but
anything is possible with enough time and resources.
Thanks again for your help Dave
I'll be quite honest, I think it would be quite difficult to implement something like this on your own.  I'm also not sure that Unity would be the ideal recording server.  I can see Contact Center fitting in there given it's capabilities to monitor/record for supervisors/agents...but Unity is a stretch for me to envision. However, I thought you might want to look a bit further at some of the capabilities of the UC 8.0 solution.  Specifically, here is a tidbit on secure call monitoring and recording.  This is just a starting place and you'd need to research this feature/capability more but...it's worth a look:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/8_0_1/secugd/secuscmr.html#wp1067763
Hailey
Please rate helpful posts!
