Aaron Harrison Tue, 07/27/2010 - 14:03
There is procedure in the manual :
Basically SSH to the server as mpxadmin, then do an 'su' to switch to root. Run 'net' and you get a menu that allows you to change the options.
Once changed, restart the system with the 'mpx_sys restart' command rather than anything else as it often doesn't start properly after making this sort of change... see this post : https://supportforums.cisco.com/message/3056740#3056740
Aaron
Please rate helpful posts...
