WLC 2112 With AIR-LAP1252
Answered Question
Jul 27th, 2010
lap 1252 is shown in CDP but not associated with wlc 2112 software version 5.1
Correct Answer by Leo Laohoo about 6 years 9 months ago
Ok.  On the AP, do a "dir" command.  You should see two IOS in the list.  One of the IOS has the "rcv" between the filename.  If you see this then DELETE the second/third IOS using the command "delete /f  /r flash:".  Reboot.  Once the AP has rebooted, run the command "lwapp ap ip address" command again.
Hope this helps.
Overall Rating: 5 (1 ratings)
Leo Laohoo Tue, 07/27/2010 - 14:56
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Could you, by any chance, provide further information?
1.  Is this happening to just one AP or all?
2.  What is the full IOS version your AP is running?
3.  Is the AP connected to an access port?
4.  Is your WLC connected to an access port?
5.  What error message do you get?
6.  Is the LAP getting a valid IP address?
Alternatively, console into the AP and enter the command "lwapp ap controller ip address ".
Please don't forget to rate useful posts.  Thanks.
k_vikrams Fri, 07/30/2010 - 02:24
Hi leolaohoo
Thanks for quick reply
1. Is this happening to just one AP or all? All ap
2. What is the full IOS version your AP is running? 12.4
3. Is the AP connected to an access port? One ap is Directly connected to WLC port no-3 and another ap is in Trunk port (there are Nortel switches)
4. Is your WLC connected to an access port? Trunk Port
6. Is the LAP getting a valid IP address? No ap is not getting IP when I am trying to configure controller ip then getting error msz - Command disabled
I am unable to reset ap also
Description: cid:[email protected]
Thanks & Regards,
Vikram Singh
Leo Laohoo Sun, 08/01/2010 - 19:20
  • Hall of Fame,
    2017 LAN, Wireless
This is the reason why your AP is not joining.  It's because the AP can't get a valid IP address.  You can't, with 5.X firmware, configure the IP address of the AP using this method.  You have to use the command "lwapp ap ip address ".
PS:  Cisco is recommending everyone to avoid 5.X like a bad smell.  Upgrade to 7.X instead.
k_vikrams Mon, 08/02/2010 - 01:49
I have Tried lwapp ap ip address
command disabled
Correct Answer
Leo Laohoo Mon, 08/02/2010 - 14:43
  • Hall of Fame,
    2017 LAN, Wireless
Hope this helps.
k_vikrams Thu, 08/19/2010 - 04:02
I have upgrade the WLC IOS
All problem has been resolved
Leo Laohoo Thu, 08/19/2010 - 17:24
  • Hall of Fame,
    2017 LAN, Wireless
Thanks for the ratings.  Again, please stay away from 5.X and 6.X firmware.  Upgrade to 7.X if you can.
