Use of LANDESK over an ASA VPN Tunnel
Jul 27th, 2010
I'm having a problem connecting our LANDESK application to remote users on a VPN tunnel.
The head device is an ASA5520 (v8.2.1), while the remote users are on a tunnel created by an ASA 5505 (v7.2.4).
While the remote office users connect well to to email, fileshares, etc., the home office can't loop them up with LANDESK.
The LANDESK server could ping the users, and vice-versa, but that's about it.
I'm guessing (a big guess) that it might have something to do with the policy maps in each ASA:
policy-map global_policy
class inspection_default
  inspect dns preset_dns_map
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect icmp
  inspect snmp
  inspect dcerpc
service-policy global_policy global
Although I have no idea if this is the case.
Could someone point me in the right direction?
Thanks!
edadios Tue, 07/27/2010 - 15:34
  • Silver, 250 points or more
I suggest doing packet capture on both Landesk facing  interfaces of the firewall, and trace where the conversation stops.
Then if you find it is related to the firewall, then use packet tracer to drill further to the cause of the issue (if it is mpf related). Usingaddreses, the protocol and ports being used to simulate the traffic through packet tracer.
Hope this helps yo get further.
Related Content
