MPF - block social sites
Answered Question
Jul 27th, 2010
ASA5505 running 8.0(4)
I added this code and it blocks the social sites as required.
It also blocks http://travel.state.gov in particular and possilby others per my customer.
Can you help me to see my error?
regex domainlist2 "\.myspace\.com"
regex domainlist3 "\.youtube\.com"
regex domainlist4 "\.facebook\.com"
regex domainlist5 "\.twitter\.com"
regex applicationheader "application/.*"
regex contenttype "Content-Type"
access-list inside_mpc extended permit tcp any any eq www
access-list inside_mpc extended permit tcp any any eq 8080
class-map type regex match-any DomainBlockList
match regex domainlist2
match regex domainlist3
match regex domainlist4
match regex domainlist5
class-map type inspect http match-all BlockDomainsClass
match request header host regex class DomainBlockList
class-map type inspect http match-all AppHeaderClass
match response header regex contenttype regex applicationheader
class-map httptraffic
match access-list inside_mpc
policy-map type inspect http http_inspection_policy
parameters
  protocol-violation action drop-connection
class AppHeaderClass
  drop-connection log
match request method connect
  drop-connection log
class BlockDomainsClass
  reset log
policy-map inside-policy
class httptraffic
service-policy inside-policy interface inside
Phil
Correct Answer by mirober2 about 6 years 6 months ago
Hi Phil,
It looks like the AppHeaderClass class is preventing you from reaching http://travel.state.gov. I did a quick capture and see that the web server's responses contain a bunch of references to:
Content-Type: application/javascript
This would be matched by the regex you have configured. Try adjusting/removing that class and the connection should go through.
Hope that helps
-Mike
Overall Rating: 5 (1 ratings)
Correct Answer
mirober2 Tue, 07/27/2010 - 14:03
Hi Phil,
Hope that helps
-Mike
Phil Williamson Tue, 07/27/2010 - 15:16
Mike,
Thanks for the reply.  That did the trick.  My problem is I'm not a MicroSquish person - that dates me as it is - so I did not know where to start.  I'll delve more into MPF because I know I need it for much more too.
Phil
Related Content
