Turning a 3560-24 port into a 48 port switch
Jul 27th, 2010
I would like to know if this is even possible? If it is possible, can I assign static mac address to route the other switch? For example:  If dest mac address matches A:B:C:D:E:F, send it to port 38.  So if Port 2 receives this packet, it will be routed to port 38.
Sounds simple enough, but i'm not sure if I can do this.
Mark
Overall Rating: 3 (1 ratings)
Leo Laohoo Tue, 07/27/2010 - 14:43
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
It is simpler if you don't.  A switch does this by default.  If the switch receives a packet it will initially send all the packets to all interface (except where it came from).  It will note down what interface receives it.  The next time a packet with the same destination arrives, the switch will look up the table and say, yes, I know who this guy is and sends it down the appropriate interface.
mark.kwong Wed, 07/28/2010 - 09:03
For my application, I MUST use static mac address using the "mac address-table static" command.
If that is the case, is it still possible?
Mark
Bobby Thekkekandam Wed, 07/28/2010 - 09:13
  • Cisco Employee,
Unfortunately, not with a 3560. With a 3750, you can use the stackwise functionality to turn two physical switches into one logical switch, and can easily statically map mac-addresses exactly as you stated.
Hope that helps,
Bobby
Leo Laohoo Wed, 07/28/2010 - 15:23
  • Hall of Fame,
    2017 LAN, Wireless
I've seen a "stunt" like this.  It was because the server has a paid application and the registration key is based on MAC address.  The easiest way for us to do is to over-ride the default MAC address of the server with a static one.
