ASA 5520 8.3 static NAT providing access to an inside Web Server
Jul 27th, 2010
Hi guys,
I have an ASA 5520 that I just setup.  I want to setup a web server behind it and I am using a Static NAT i setup via the CLI.  For the life of me I cannot get it to work.  Here is a simple diagram of my setup.
Am I missing something obvious to make the web server accessible from the Outside?
Now here is my config:
ASA Version 8.3(1)
hostname ASA
domain-name community.com
enable password
passwd
names
dns-guard
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 70.1.1.101 255.255.255.224
interface GigabitEthernet0/1
description ****TRUNK****
speed 1000
duplex full
no nameif
no security-level
no ip address
interface GigabitEthernet0/1.174
vlan 174
nameif inside
security-level 100
ip address 192.168.174.4 255.255.255.0
interface GigabitEthernet0/1.175
vlan 175
nameif dmz
security-level 50
ip address 192.168.175.1 255.255.255.0
interface GigabitEthernet0/2
nameif waf
security-level 25
ip address 10.10.175.1 255.255.255.0
interface GigabitEthernet0/3
description LAN/STATE Failover Interface
speed 1000
duplex full
interface Management0/0
nameif management
security-level 100
ip address 192.168.99.201 255.255.255.0
management-only
boot system disk0:/asa831-k8.bin
ftp mode passive
dns server-group DefaultDNS
object network my-inside-network
subnet 192.168.174.0 255.255.255.0
object network waf-network
subnet 10.10.175.0 255.255.255.0
object network TESTWEBSERVER
host 10.10.175.254
access-list DMZ_IN extended permit icmp any any echo
access-list DMZ_IN extended permit icmp any any echo-reply
access-list OUTSIDE_IN extended permit tcp any host 70.1.1.102 eq 8000
access-list OUTSIDE_IN extended permit tcp any host 70.1.1.102 eq www
access-list OUTSIDE_IN extended permit icmp any any
pager lines 24
logging buffered debugging
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu waf 1500
mtu management 1500
mtu dmz 1500
failover
failover lan unit primary
failover lan interface FAILOVER GigabitEthernet0/3
failover link FAILOVER GigabitEthernet0/3
failover interface ip FAILOVER 5.5.5.5 255.255.255.0 standby 5.5.5.6
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-631.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
nat (waf,outside) dynamic interface
nat (waf,outside) static 70.1.1.102
access-group OUTSIDE_IN in interface outside
access-group DMZ_IN in interface dmz
route outside 0.0.0.0 0.0.0.0 70.1.1.99 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.99.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
service resetoutside
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh 192.168.99.0 255.255.255.0 management
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:914c3f6a31fc8e1a249f922585ba6f00
: end
Overall Rating: 5 (1 ratings)
Panos Kampanakis Tue, 07/27/2010 - 14:57
  • Cisco Employee,
You probably want to statically translate 10.10.175.254 to 70.1.1.102. That part is fine.
If you are testing inbound connection you need to use the real ip in the outside ACL
access-list OUTSIDE_IN extended permit tcp any host 10.10.175.254 eq 8000
access-list OUTSIDE_IN extended permit tcp any host 10.10.175.254 eq www
That is a change that came with 8.3, for simplicity so that you don't need to remember the global ip of a host.
Let us know that it solved the issue so other can benefit in the future.
PK
Joshua Engels Tue, 07/27/2010 - 15:02
I figured it out right before your post.  I was not using the
real IP address.  Thanks for your response!
-Josh
