AAA authentication session to FWSM module
Bruce Summers
I need to pose a question:
I understand that the authentication process is managed in the admin context...I presently have module setup to authenticate with a local account.  However, I'd like to configure the telnet session from the switch to the FWSM using AAA.
I have a configuration on the specific contexts that allow me to SSH into the contexts, using AAA authentication, as follows:
aaa-server <group> protocol tacacs+
aaa-server <group> (outside interface) host <ip>
aaa auth en con <group> LOCAL
aaa auth ssh con <group> LOCAL
I'm a little leary about modifying the admin context for the type of auth (dont want to lock myself out)...
So, my question is, as long as i can communicate with the TACACS appliance(s) from the admin context, should the config that I'm using work for my telnet session from the switch to the FWSM?.
thanks.
bruce
Bruce Summers
Well,
I got it to work up to the point of authenticating the enable access...
so, when i authenticate into user mode to the FWSM, it performs the auth...when i then try to enter exec mode (Enable) it isnt auth aaa...its using the local database...
thoughts?
bruce
