flat network
sarahr202
Level 5
Level 5
Hi every body.
I have few questions.
i was reading u flat network.  I googled it and found following:
One diagram shows  a hub    connected to hosts.
So  I thought  a flat network  is a network where broadcast send by one host will be head by all.
Then i saw another diagram ,showing  a switch connected to hosts.
It is possible that a switch might have vlans configured to separate hosts from talking to each other in absence of router/l3 switch. This prompted me to review my original concept based on first diagram.
I am still at loss what is the criteria to declare a network as flat network?
thanks and have a good day.
2 Accepted Solutions
Gregory Camp
I'm pretty sure the definition of a flat network is a single broadcast domain which can be accomplished with a hub or a switch.
Jon Marshall
Sarah
Just to add to Gregory's reply.
A flat network is indeed a single broadcast domain and this can be achieved using a switch or hub. If you use a hub you also have a single collision domain whereas with a switch you don't ie. each switch port is it's own collision domain.
Note also that we often refer to a flat L3 network as one where you have one network range for the whole network ie. it has not been subnetted down.
Jon
Gregory Camp
Thanks Gregory
Jon Marshall
Sarah
Jon
