802.1x dynamic vlan assignment based on MAC?
Answered Question
Jul 27th, 2010
I am using Catalyst3750 and Widows AD Authentication.
Our customers' pc is runnnig Windows (isn't 802.1x capable) that is connected to the catalyst switch.
Is it possible to dynamic assign a Vlan based on MAC?
When possible, we want to make it without using VMPS.
and, is there any document relating to the above.
Thanks a lot for you help.
Tomoyuki
Correct Answer by cwerny@ernw.de about 6 years 7 months ago
Hello Tomoyuki,
which Radius Server are you using to authenticate your Clients?
For the Secure ACS you can configure a feature called "MAC-Authentication-Bypass" which fullfils your requirements.
This Feature must be configured on the Switch and on the Radius Server (which does the vlan assigment based on the MAC-Address of the Client)
An Overwiew of this feature can be found here:
http://www.cisco.com/univercd/cc/td/doc/solution/macauthb.pdf
I hope this helps,
Kind regards,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
cwerny@ernw.de Thu, 07/29/2010 - 05:26
Hello Tomoyuki,
I hope this helps,
Kind regards,
Chris
t-yamashita Thu, 07/29/2010 - 17:15
Hello Chris,
I'm using radius that secure ACS server.
Thanks a lot  for your help.
I appreciate it.
Tomoyuki
