Jul 27th, 2010
How can i select VIC'S for CISCO 2801 and 2811 Routers? what need to be considered?
Aaron Harrison Wed, 07/28/2010 - 01:36
You need to first consider what you need the VICs for - i.e. what type of PSTN circuits are available to you, how many channels you need, etc.
You then need to select an appropriate card that is compatible with your router - for a 28xx this is typically a VIC2-something, but check here :
Finally, depending on the number of channels you need, you then specify PVDM modules :
Please rate helpful posts...
