caller-id on fxo port callmanager express 3.3
Answered Question
Jul 27th, 2010
I've a CME 3.3 on cisco 1751-V (IOS 12.4..24c).
IN the router it's installed a vic 2 fxo where is connected one analogic line.
the related voice-port has the following configuration:
voice-port 1/0
translation-profile incoming ENTRANTI
no comfort-noise
cptone IT
connection plar opx 200
I'need to enable the caller-id on this port (for default it is disables)  but the command is "unknown" and doesn't appears if I press  the ? key for help.
this is the list of command displayed when I ask help
POP_CSN(config-voiceport)#?
Voice-port configuration commands:
  battery-reversal     Enable FXO battery-reversal detection
  bearer-cap           Specify the bear capability
  busyout              Configure busyout trigger event & procedure
  comfort-noise        Use fill-silence option
  connection           Specify Trunking Parameters
  cptone               Configure voice call progress tone locale
  default              Set a command to its defaults
  description          Description of what this port is connected to
  dial-type            Configure type of dialer for voice
  disc_pi_off          close voice path when disconnect with PI received
  echo-cancel          Echo-cancellation option
  exit                 Exit from voice-port configuration mode
  impedance            Specifies the terminating impedance of the interface
  input                Configure input gain for voice
  music-threshold      Threshold for Music on Hold
  no                   Negate a command or set its defaults
  non-linear           Use non-linear processing during echo cancellation
  output               Configure output attenuation for voice
  playout-delay        Configure voice playout delay buffer
  pre-dial-delay       FXO Pre-dial Delay
  ring                 Number of rings
  shutdown             Take voice-port offline
  signal               The signaling type for the interface FXS or FXO
  snmp                 Modify SNMP voice port parameters
  station-id           Configure station ID
  supervisory          Configure answer + disconnect supervision options
  threshold            Threshold [noise] for voice port
  timeouts             Configure voice timeout parameters
  timing               Configure voice timing parameters
  translate            Translation rule
  translation-profile  Translation profile
  trunk-group          Configure interface to be in a trunk group
any suggest?
Thanks in advance
Giancarlo
Correct Answer by Steven Holl about 6 years 8 months ago
That card doesn't support CLID.
You need a VIC-2FXO-M2 for CLID support in Italy.
-Steve
Overall Rating: 5 (1 ratings)
Correct Answer
Steven Holl Thu, 08/05/2010 - 07:23
  • Cisco Employee,
-Steve
