Can't select single device in netconfig RME
Jul 28th, 2010
I want to do a job in netconfig, but can not select any device. I get an error " no device has been selected " . This problem has been reported here on the forum https://supportforums.cisco.com/message/3111643#3111643 , but i am not sure if it is exactly the same.
All help is appreciated,
thx Bogdan
bogdand27 Thu, 07/29/2010 - 02:14
Can anyone help me with some advice? I can not tell if rmepaketesmaps are corrupt. How can I tell if they are corrupt? Thank you very much.
Martin Ermel Thu, 07/29/2010 - 04:45
  • Blue, 1500 points or more
following the thread you mentioned,post the list of files under
NMSROOT\MDC\tomcat\webapps\rme\WEB-INF\lib\pkg
NMSROOT\www\classpath\com\cisco\nm\xms\psu\pkgs\rme
and to do it in one step, also post the following files:
NMSROOT\www\classpath\com\cisco\nm\xms\psu\maps\rme*
NMSROOT is the installation directory of LMS (e.g. C:\Program Files\CSCOpx)
