CISCO 2960 QOS
Jul 28th, 2010
hello world,
i'm trying to limit bandwitdh with a Catalyst 2960
as to users from a port are limited for upload and dowload speed 80 Mbps
i tried with policy-map attached to a port but i don't understand how to fix the burst size ::
does any one could help me to understand !!!
Jayakrishna Mada Thu, 07/29/2010 - 21:38
  • Cisco Employee,
Burst size really depends on your traffic pattern and it is hard to give you a specific value.
If you are attaching a policy-map to a port it only does input policing, cannot do egress policing.
try this command under the port that you are testing and see if that helps "srr-queue bandwidth limit 80".
JayaKrishna
vpancisco Mon, 08/16/2010 - 04:56
thanks for your interest,
but i want to limit UPLOAD AND DOWNLOAD as to have a symetric bandwidth ...
so INGRESS and EGRESS bandwidth limiting
does it's so hard to do with Cisco Products ???
