Unity Connection 1 (Win2003) Location of Message store & SQLdatabase
Jul 28th, 2010
Hi All,
I'm not familiar with unity connection 1, therefore I would be most grateful for a little advice.
I would like to confirm the Location (i.e. Drive, path & folder ) of The Message store and MSSQL + database store.
Thanks in advance
Charles
Scott Hills Mon, 08/02/2010 - 06:03
  • Cisco Employee,
In Unity Connection 1.x we started to store the messages in SQL databases. The default is called UnityMbxDb1.
You can determine the location of your database by opening SQL Enterprise Manager and Expanding to the Databases Folder. Then Right click on UnityMbxDb1 and Properties. Click on 'Data Files' and 'Transaction Log' tab and this will show you the location of the database and it's transaction log file.
Hope that helps,
Scott
