Place call is not working in HTTP trigger script
Jul 28th, 2010
I have basic hello script with HTTP trigger and CUCM trigger configured as well. I am trying to dial out an extension and play an prompt in my script. Running UCCX 7.0.1 with premium license. The place call step doesnt start at all when I do the debug. HTTP trigger and response works fine. Anything I am missing in the script.
Jonathan Schulenberg Wed, 07/28/2010 - 05:12
Create a Contact-type variable. Set the Place Call and Play Prompt to this second contact. You cannot play a prompt or make a call to the triggering contact when the script was triggered by an HTTP contact instead of JTAPI.
Gabriel Saavedra Wed, 07/28/2010 - 08:13
After changing the play prompt to the contact variable, also check the call control group id and the dialog groups of the place call step, just to see if you are using the correct ones.
