LMS 3.2: Software Distribution - Generic Error
Jul 28th, 2010
Hy.
I need to roll out an IOS on r.a. 250 devices. But when I try to distribute any software image via RME I always get the same error. I'm unable to start the job because in step one after selecting image and devices I get "failure" for all devices. When I click on "failure" a pop-up window opens telling me "generic error". Please have a look at the attached screenshot.
What does this mean and how can I fix this? This is really urgent!
All devices are completely managable (and managed) by the LMS.
Thank in advance!
Marc
Nael Mohammad Wed, 07/28/2010 - 10:32
Which IOS image are you trying to deploy and which device ?
Go to Common Services --> Software Center --> Software Update and provide screenshot.
Go to RME --> Admin --> Software Management ---> View/Edit Software Prefrences and check to see if "Include Cisco.com image "  for recommendation is selected.  If not, check them.
Try a different image that is higher that the current one and or use a GD image.
mwynen Thu, 07/29/2010 - 05:20
Hy.
We have to use c2960-lanbasek9-mz.122-44.SE3.bin with Catalyst 2960 switches. But we have the same effect with c3560-ipbasek9-mz.122-44.SE3.bin and Catalyst 3560 switches.
The IOS is a customers requirement!
I've checked the "Include Cisco.com image" box and tried it again. The result is the same as before.
You can find the screenshot of the software-center attached.
cheers
Marc
Martin Ermel Thu, 07/29/2010 - 06:02
enable SoftwareMgmt debugging in RME > Admin > System Preferences > Application Log Level Settings start the job and post the output of NMSROOT\log\swim_debug.log
mwynen Thu, 07/29/2010 - 06:17
I've activated debugging, but as I told you before I can't start the job. Nevertheless you can see inside of this log that I was trying to and got an error.
Needed to zip it because it was much too big.
cheers
Marc
Martin Ermel Thu, 07/29/2010 - 06:31
please post a screenshot of RME --> Admin --> Software Management ---> View/Edit Software Prefrences
Martin Ermel Thu, 07/29/2010 - 07:08
so you have ssh enabled on the devices and DCR
has the credentials in its database?
Sorry, - but have you yet loaded the images into the SWIM repository of RME ?
mwynen Thu, 07/29/2010 - 07:23
Yes, the credentials are stored in the repository and the creden tials check is successfull for all devices.
See a screenshot of the repository. I've checked the two IOS images i was tralking about earlier.
cheers
Marc
Martin Ermel Fri, 07/30/2010 - 13:21
in one of the logs I see an error when the process trys to read the repository  but I do not see why - perhaps it is a device package problem or a bug with one of the dev.pkgs..-
I am sorry but I will be on vacation the next 3 weeks - so hopefully somebody else jumps in ...
