Creating a Route Pattern
Answered Question
Jul 28th, 2010
  • Bronze, 100 points or more
I am having a problem as our Call Manager (5.1.3) uses an old version of the UK Dial plan that does not include new local rate 0843 numbers.
I have been told I can configure a route pattern to route calls out onto the PSTN.
We have an MGCP voice gateway with ISDN PRI.
Looking at the route patterns (which were setup by our service provider) we have setup and they are all ‘9.@’.
e.g.
Pattern: 9.@
Route Partition: National-Rate-Access
Number Plan: GBNP
Route Filter: National Rate Access
I have tried adding 9.@0843XXXXXXX
When I use the Dialled Number Analyser it still says:
‘Match Result = BlockThisPattern’
Where as when I enter an 0845 number for example:
‘Match Result = RouteThisPattern’
Many thanks in advance.
Correct Answer by htluo about 6 years 10 months ago
Shouldn't it be 9.0843XXXXXXX instead of 9.@0843XXXXXXX?
Michael
http://htluo.blogspot.com
Overall Rating: 4 (2 ratings)
mmoulson1 Wed, 07/28/2010 - 06:24
Many thanks!
I noticed when you don’t include the [email protected] symbol the Number Plan field is greyed out.
Just tested it on DNA and it is now showing:
Matched Pattern Information
Pattern = 9.0843XXXXXXX
g1smdvoip Fri, 12/02/2011 - 03:27
  • Silver, 250 points or more
Don't forget to also add the new UK-WIDE 03XX XXX XXXX numbers too.
http://www.aa-asterisk.org.uk/index.php/03_numbers
Additionally, 084X numbers cannot be described as "local rate" and 087X numbers cannot be described as "national rate" since they cost a lot more to call than a standard 01 or 02 geographic number. These are "special rate" or "business rate" numbers.
