Nexus 5000, 2000 and vss
Tony MALPASS
Could you recommend a cisco book that covers the configuration and intergration of the above mentioned technologies.
cheers
tony
5 Replies 5
Reza Sharifi
Tony,
There is not really a book that explains the technology and integration.  Your best resource is the config guides
here is one for VSS:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html
Reza
Great post..
I have scenario where in 2 N5k's in a pair are connected to vss (upsttream)in a single port channel. For testing the failover and end to end connnectivity, I tried to ping from a fex on N5k to a switch connected to VSS s/w. In the mean while I rebooted the primary but the ping didn't drop but as soon as  the primary N5K was up I could see 6 to 7 ping  drops and againn it started pininng continously..
Can u guyz help me with it.
no anwer but I intend to install VSS + N5k by end of the year ... so interested by conclusions if you find origin of the problem.
could you attach your topology?
Regards.
