Pix 501 Port Redirection with outside Dyn IP for DVR
Jul 28th, 2010
I have a pix 501 6.3 version soft. I need to access my cameras from the net. the camera address is 192.168.1.60:1042
my ISP outside  is dynamic.
The following is my config, please let me know what is wrong with it.
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password bJT00RrZ7Q9S5J1B encrypted
passwd bJT00RrZ7Q9S5J1B encrypted
hostname Haiyai
domain-name ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside permit tcp any interface outside eq 1042
access-list outside deny ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface 1042 192.168.1.60 1042 netmask 255.255.255.255 0 0
access-group outside in interface outside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:57847b305111572396f1ae0410e54f7e
: end
Morgan
Panos Kampanakis Wed, 07/28/2010 - 07:48
  • Cisco Employee,
Morgan,
Your config is perfectly fin. You have your PAT static and opened the ACL for that port
access-lis outside deny ip any any
The issue is somewhere else. When you try to connect check the conn through the PIX "sh conn | i 192.168.1.60", and you should see the conn.Check if the camera needs more ports to open and what the PIX logs show.
I hope it helps.
PK
Related Content
