How do I get "Dial 9 For an Outside line" to appear at the bottom of a 79XX phone?
Answered Question
Jul 28th, 2010
Saw a phone at a local retailer that had "Dial 9 For An Outside Line" how do I add that to my 79XX series of phones?
Correct Answer by Steven Holl about 6 years 11 months ago
What does the status line currently display?  If it says 'Your current options' then you have CUCM.  If it says something like 'Cisco Unified CME' then you have CME.  The former cannot be changed, the later is done with these commands:
enable
config t
telephony-service
system message "message"
reset all 1 <---resets all phones
exit
exit
wr <---saves config
Overall Rating: 5 (1 ratings)
Aaron Harrison Wed, 07/28/2010 - 08:11
  • Community Spotlight Award,
    Member's Choice, May 2015
With CUCME you can use a 'system message' command under telephony-service config to set that line.
I don't believe you can set it on a CUCM system.
Aaron
Please rate helpful posts....
aejhpp9 Wed, 07/28/2010 - 08:18
I appreciate the reply but how do I know if what I have is CUCME or CUCM?
Aaron Harrison Wed, 07/28/2010 - 12:59
If you don't know you'll struggle to configure it :-)
CUCM is server based and uses routers for PSTN connectivity and other stuff, whereas CUCME is based on a router only.
Aaron
Correct Answer
Steven Holl Thu, 07/29/2010 - 11:46
  • Cisco Employee,
enable
config t
telephony-service
exit
exit
wr <---saves config
