Catalyst 6500 and 4500 Ether-channel load balancing
Jul 28th, 2010
How can I find out if my load balancing is truly balancing the load across my links? In other words how can I see the traffic load on each of the links in the channel?
Mike
Overall Rating: 5 (2 ratings)
Chetan Kumar Ress Wed, 07/28/2010 - 12:25
Hi Burley,
The below chart show the Ether-Channel load balancing.
Number of Ports in the EtherChannel
Load Balancing
8
1:1:1:1:1:1:1:1
7
2:1:1:1:1:1:1
6
2:2:1:1:1:1
But to check real time traffic i suggest you to use SNMP ( Bandwidth monitoring for those switch ports )
It can give you good report that any command line in switch.
Regard
Chetan Kumar
http://chetanress.blogspot.com
burleyman Wed, 07/28/2010 - 12:48
Thanks for the chart, I did already look at that. I was checking to see if there was a coomand that would give me some indication as to the load on each of the links.
Mike
Jon Marshall Wed, 07/28/2010 - 15:59
Mike
What if you just look at each interface to see the load/packets transmitted and received. Would that not tell you how it was load-balancing the traffic across the links ? You could clear the counters to get a base to start with.
One other thing - what does "sh etherchannel load-balance" show ? From memory i don't think it shows what you want but can't remember to be honest.
Jon
burleyman Thu, 07/29/2010 - 04:29
Jon,
Thanks for pointing out the obvious....some times I wonder about my mind and over thinking the obvoius....
As for the command   sh etherchannel load-balance   it just show what Load Balancing method is in use.
I cleared the counters and I will check later.
Thanks for your Help Jon.
Mike
